Has anyone had a problem where Keil compiles with no errors then crashes when debugging. And then with the same code, different program it creates error messages? Thanks Gab.
...with the same code, different program What's that supposed to mean? Either it's the same, or it's not. Which of these is it? That set aside, please note that software acting differently on repetitions of the same job is usually more likely to be the symptom of a hardware instability than anything else.
