Hello, My name is Mihai Pogorevici. I need little assistance and i would be very happy if someone would agree to help me. I'm working on a big project which includes microcontroller programming and i use Keil uVision 2.20a (C51 ver 6.20c, A51 ver 6.20, BL51 ver 4.20). Question 1: Does Keil C51 support Assembler statements within the C code ?! Question 2: How could i call another program loaded in memory (written in Keil C) within from a C51 program (written in Keil C too) ?! We suppose that we know the startup address. I tried to use an external assembly module to call another program but it didnt work at all. I really need help. Can someone give me any example ?! Thank You, Mihai Pogorevici. P.S. My target system is a Philips 80C552.
Does Keil C51 support Assembler statements within the C code ?! Yes. Read the C51 manual for the details. Calling external functions at known addresses can be either hard or simple, depending on how, exactly, they were made. I.e.: do they take arguments? If so: where? What about return values? It can be as simple as
typedef void (*func_ptr)(int); func_ptr whatever_function = (func_ptr) 0x12345; funcptr(5);
