I am using Emulator Phillips PDS51-MK2A motherboard and PDB66x-Rx2 daughtboard, Keil uVision2 compiler and I can't load Object file OMF51.There is a message when I load the object file:"unknown OMF record (type C4) found in file". Can anyone help? Nguyen The Son. Thanks
You haven't given any versions, which doesn't help. :-( Are you using Keil's new improved OMF2 format? If so, does your emulator support it?
