Hello, I'm interested in building a little serial configuration UI for my current design which controls the terminal in a user-friendly way. Does anyone know of a (perhaps miniaturized) curses port or other reasonably rich terminal control library for C51? Thank you. Sasha Jevtic
When I've done this I've always used a command-line interface on the 8051 (it's a lot easier to implement and it requires only a little code space). Then, I've created a GUI in whatever connecting application I was using (VB, VC++, DOS, ...). That way, I could add lots of fancy features to the GUI without impacting my embedded application. Jon
