i want to use ibanking, so am using control-switch of ibanking in BL51_Misc controll on option-menu. micom is sda5550m(Microna). The problem is that when function in one bank call function in another bank, there is no return. there is no problem when function in one bank call function in same bank. tell me why the problems happen. and how much times call inter-bank ?( one bank call another bank, another bank call another bank ) i use keil compiler v6.20 and linker v4.20. if i use the oldest version linker( v3.70 ) there is no problem.. tell me why the difference.... thank you for reading my poor english.. God bless you !!!
Have you modified the example L51_BANK.A51 code to match your banking hardware, and included it in your project? (And modified STARTUP.A51 to initialize the banking logic?)
Please don't just keep on starting new threads on exactly the same subject! You already have replies awaiting your response in two of your previous Threads: http://www.keil.com/forum/docs/thread3671.asp http://www.keil.com/forum/docs/thread3602.asp In particular, have you seen the "*** IMPORTANT ***" note at: http://www.keil.com/dd/chip/3257.htm
