Hi, Does os_send_token() cause task switching?If so, my code given below is not working properly,task_1 is running continuously, and task_2 is never getting executed. Please clarify my doubt. void setup_serial_io (void) { SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 0xF0; /* TH1: reload value */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ } void task_1 (void) _task_ TASK1 _priority_ 0 { while (1) { // Delay for 200 ticks os_wait (K_MBX + SEM_PRINTF, 255, 0); // Wait for printf printf ("Task # %d\n", (int) os_running_task_id ()); os_send_token (SEM_PRINTF); // Done with printf } } void task_2 (void) _task_ TASK2 _priority_ 0 { while (1) { os_wait (K_MBX + SEM_PRINTF, 255, 0); // Wait for printf printf ("Task # %d\n", (int) os_running_task_id ()); os_send_token (SEM_PRINTF); // Done with printf } } regards, srilatha.
I don't believe it does. Take another look at the example in http://www.keil.com/support/docs/690.htm. There is a short delay before checking for the semaphore. I seem to recal that this was used in the example to allow other tasks to run. Jon
Thanx for your reply Jon.Is is correct that, to switch from one task to another a short delay must be there? or is there any other way? regards, srilatha
Yep - That's correct. Jon
