I need to shift data into serail input register bit-by-bit. It would be nice, if the compiler would support asm blocks in a C program. 1. Shifting a byte is done by rotatig accumulator left, whereby the msb is loaded into carry flag. The docs that are provided with C51 evalution demo don't inclute any descriptions of the supported language operations. Will the operation ACC <<= 1 move the msb into CY? 2. After the ACC is shifted and CY flag is loaded with the bit that I need to submit to the input of the shift register via P0.3, I try to make use of C51 bit addressing. The sbit declaration example I've copied from C51 User's Guide and inserted into my program, doesn't work. Dear Sir, have you checked the snippet of code below?
int bdata ibase; /* Bit-addressable int */ sbit mybit0 = ibase ^ 0; /* bit 0 of ibase */
The 8051 architecture makes the carry flag available just as with any bit in an SFR, so the Keil compiler will let you access it in C. However, the C language standard doesn't make any reference to a carry flag, so you can't count on any particular operation affecting or using the flag. So, you can inspect the assembly code generated for a C operation like a shift, and write code to take advantage of that fact. But such code will be brittle, highly dependent on the code generator, and thus is perhaps not the best way. You could just write a loop in nearly pure C to output the byte, something like:
for (i = 0; i < 8; ++i) { P3_0 = (byte & 0x80) ? 1 : 0; byte <<= 1; }
