I need to transmit a string of message between two Radio frequency transmitter. The message will be stored a microcontroller (e.g. 8051). How to go about writing a program for it and how to interface between the micrcontroller and the transmitters. I am still an amauteur when comes to embeded programming. Any source code or info on this ?
What i wan to get is the circuit.. I can't seem to find any circuit.. Any site to recommend
http://instruct1.cit.cornell.edu/courses/ee476/FinalProjects/s2003/yc234/website/schematics.html
Christo, I am currently trying to send data from the pc by the serial port to a rf transiver and then received by another rf transiver to be accepted by a PIC. Any simple source code to help me out. I am stuck on how to get the PIC to accept the RF signals and decode them to proper PIC signals.
Better go to a PIC forum, then!
hi,,, i need how to interface the 8051 at an RF tarnsmitter,,, please send code
Hi Manoj Do you have any circuit idea for transmitter/receiver module. Or any module available in India for hobby projets. Thanks
how to interface an 8051 to an RF transmitter ? -------------------------------------------------------------------------------- I need to transmit a string of message between two Radio frequency transmitter. The message will be stored a microcontroller (e.g. 8051). How to go about writing a program for it and how to interface between the micrcontroller and the transmitters. I am still an amauteur when comes to embeded programming. Any source code or info on this ?
please send circuit to my email khalili_m1@yahoo.com
can u help me to select a RF module for data communication between devices and to interface to microcontroller(PIC).
"and to interface to microcontroller(PIC)." You'll need to find a PIC forum for that!
"can u help me to select..." Nobody can help you select anything when you've given no criteria at all on which to base the selection! Besides, this is a forum for discussing Keil software tools - not hardware selection!
our teacher told us to search for a simple project that 8051 could be apply..just a simple projects that is not costly...affordable for the students can you give and example of this project?can you send me?
can you send me a sample projects...a simple projects not that is not so expensive and easy as well..
"our teacher told us to search ... can you send me?" Let's just read that again - who is supposed to be doing the searching: "our teacher told us to search" So off you go - get searching!
There are already 8051 devices with built-in RF Transceiver. Take a look to the parts from Nordic (http://www.keil.com/dd/cl/nordic/8051.htm) or Chipcon (http://www.keil.com/dd/cl/chipcon/8051.htm). Both companies supply starter kits with example projects that help you to get started quickly.
