Hi all I want to add Asm file to a 'C' project. Project has one '.c'and one '.h' file. Assmbly file to be added is with '.a51' extension.only one routine is added to a51 file,which is called from main.A51 file is getting assembled successfully,but project is not getting compiled as whole. decleration in main file is :
extern void delay_asm(unsigned char);
void main() { . delay_asm(2); . }
PR?delay_asm?delay_asm SEGMENT CODE PUBLIC delay_asm delay_asm: USING 0 mov a,R7 rv:dec A Jnz rv RET END
You need to add an
RSEG PR?delay_asm?delay_asm
The easy and error proof way to do this is to first code a skeleton routine in 'C'. Then use the generated assembler as a template for your assembly code. Erik
For such a simple loop why don't you stay in "C"
void Delay (unsigned char Cycles) { while (--Cycles); }
DELAY1: DJNZ R7,DELAY1
For such a simple loop why don't you stay in "C" This function generates super efficient code Maybe and maybe not depending on brand, options and release. There is absolutely no guarantee that C will generate any specific code. Thus all timing must be in assembler. There is no end to the bitbanging and other time critical routines I have seen fall apart because the Compiler got upgraded/replaced. Erik
If you really want accurate timing, use a timer. Even hand-tweaked assembler loops can fall apart the instant you change parts (12 clocks per instruction? 4? 2?), or oscillator frequency, or perhaps the external memory subsystem timing. Any function you put in software -- in whatever language -- will leave you potentialy liable for software maintenance when the environment changes in just the wrong way.
Thanks for reply. following was the code after modification.
EXTRN CODE (mod_delay) PUBLIC delay_asm code_asm SEGMENT CODE RSEG code_asm using 0 delay_asm: mov A,R7 rv:dec A Jnz rv call mod_delay RET END
Rename the label "delay_asm" to "_delay_asm" in your assembly file. The compiler wants to see a leading "_" on any function that passes parameters via registers. Since delay_asm is using r7, it needs a leading "_".
Thanks bill code is working. Asm routine is getting called from main and 'C' routine from asm. so if no parameters are passed ' _ ' is not required. code after adding ' _ 'is:
EXTRN CODE (mod_delay) EXTRN DATA (var_global) PUBLIC _delay_asm code_asm SEGMENT CODE RSEG code_asm using 0 _delay_asm: mov A,var_global rv:dec A Jnz rv call mod_delay RET END
mov A,R7 ;take low byte of var_int to acc .. ; logic oprns mov A,R6 ;take high byte of var_int to acc
EXTRN DATA (var_int) .... mov DPTR,var_int
can i write mov DPTR,var_int No - Although the 8051 does a decent job manipulating the 16 bit DPTR, it is an 8 bit processor and just can't do this in one instruction. The DPTR can be loaded with a constant value in one fell sweep, but not with the value contained in a variable. Stick with: mov A,R7 ;take low byte of var_int to acc .. ; logic oprns mov A,R6 ;take high byte of var_int to acc or, if you want this value in DPTR do: mov DPL, R7 ;DPL is low byte of DPTR mov DPH, R6 ;DPH is high byte of DPTR Bill
Hi Bill since we have started discussion on assembly <----> 'C' why don't we discuss other issues which are related to this topic.This can be helpful to all. Every body is invited to share different type of problems they experience while workin with C <-> Assembly. regards Naresh
"Every body is invited to share different type of problems they experience while workin with C <-> Assembly" Better to make that a new thread - with a relevant Subject line. Of course, you'd start with a link to this one!
