Why does my program always start from C:0x00AE?
Dear all,
Thank you for your help in advance.
I created a very simple program to test my Monitor-51 which is showed below:
#include "AT89X55.H"
sbit P25 = 0xA5;
void DELAY(int j)
 int i;
 for(;j>0;j--)
   for(i=2;i>0;i--)
main(){
while(1)
    P25 = 0;
    DELAY(1);
    P25 = 1;
    DELAY(1);
When I debugged this program by using Monitor-51,the first line is always "C:0x0000 0200AE LJMP c:00AE" in
the Disassembly window,and the other lines are:
C:0x00AE    E4       CLR      A
C:0x00AF    F5CB     MOV      RCAP2H(0xCB),A
C:0x00B1    F5CA     MOV      RCAP2L(0xCA),A
C:0x00B3    F5CC     MOV      TL2(0xCC),A
C:0x00B5    F5CD     MOV      TH2(0xCD),A
C:0x00B7    F5C9     MOV      T2MOD(0xC9),A
C:0x00B9    F5C8     MOV      T2CON(0xC8),A
C:0x00BB    20B0FD   JB       RXD(0xB0.0),C:00BB
C:0x00BE    30B0FD   JNB      RXD(0xB0.0),C:00BE
C:0x00C1    D2CA     SETB     TR2(0xC8.2)
C:0x00C3    30B003   JNB      RXD(0xB0.0),C:00C9
C:0x00C6    30CFFA   JNB      TF2(0xC8.7),C:00C3
C:0x00C9    30B0FD   JNB      RXD(0xB0.0),C:00C9
C:0x00CC    30B003   JNB      RXD(0xB0.0),C:00D2
C:0x00CF    30CFFA   JNB      TF2(0xC8.7),C:00CC
C:0x00D2    30B0FD   JNB      RXD(0xB0.0),C:00D2
C:0x00D5    C2CA     CLR      TR2(0xC8.2)
C:0x00D7    20CFD4   JB       TF2(0xC8.7),C:00AE
C:0x00DA    AFCC     MOV      R7,TL2(0xCC)
C:0x00DC    AECD     MOV      R6,TH2(0xCD)
C:0x00DE    EE       MOV      A,R6
C:0x00DF    C3       CLR      C
And I failed to change the statement by use of "Inline assembly".Why the assembly try to initial the timer2? I wonder if the MON51.HEX createad by INSTALL.A51 is fit to AT89S52? The MCU is AT89S52. I set the Option for target as follow: Off-chip code memory Start:0x8000, size:0x3fff, Off-chip Xdata memory Start:0xc000, size:0x3fff. When I use simulator to debug this program there is no problem. Can you give me a hand? Thanks.
  • The MON51 documentation will tell you what resources it requires in your hardware.
    Have you checked?
  • Yes. I have checked it carefully according to MON51.
  • The LJMP you see is where the reset vector jumps to the monitor program.
    If you program must start at address 0x8000 (when using the monitor) then you must do more than simply specifying the starting CODE address. Refer to the following knowledgebase article:
    http://www.keil.com/support/docs/189.htm
    Once the program downloads to the monitor, you may also have to specify the starting address ($ = 0x8000). It's probably a good idea to uncheck Go Til Mail in the debugger options.
    Jon
  • "Why the assembly try to initial the timer2?"
    Because that's what it says on the tin:
    "The monitor [MON51] uses a serial interface with a timer as the baudrate generator." (my emphasis)
    It's in the uVision Getting Started Guide - in the MON51 section.
  • Thank you. My setup is just as what "C51: SETTING PROGRAM START ADDRESS" says and I got the same result. In addition, when I stepped over the program,it halt at
    ,then I pressed the "reset" button on the MONITOR51 board and received error information
    "try again"/"setting"/stop session". I selected "try again",now the PC jumped to 0x8000.
  • Why does my program always start from C:0x00AE?
    This question reminds me of a Peter Sellers movie.
    A man asks an innkeeper, "Does your dog bite?" The innkeeper said, "No." The man leans over to pet the dog and the dog nearly eats his hand off. He turns to the innkeeper and says, "I thought you said your dog did not bite." The innkeeper responds, "That is not my dog."
    I guess my smart-aleck answer to "Why does my program always start from C:0x00AE?" is, "That is not your program!"
    Jon
  • Hi Rinfen,
    Did you solve your problem finally?
    I am encountering a similar problem as yours, i.e. the first line is always
    At 0x00AE the instruction is
    C28E CLR TR1(0x88.6)
    once I step this the monitor losts connections with uVision2...
    I follow exactly what mentioned in "C51: SETTING PROGRAM START ADDRESS" however the reset vector persists as 0x00AF...
    As you suggested after the dialog box appears, reset the target and "Try again", can get the monitor communicates with uVision2 again and can start debugging...
    Are there any undocumented steps that I missed to follow?
  • That first instruction is the reset for the monitor.
    Did you relocate your program to a different starting address?
    If so, your program will appear at that address and not at 0000h.
    Jon
  • Hi Jon,
    Following instructions in "C51: SETTING PROGRAM START ADDRESS",
    I did:
    Change the startup code...
    1. Copy the STARTUP.A51 file from the \C51\LIB directory to my project directory.
    2. Search for CSEG AT 0000h and change it to CSEG AT 8000h.
    3. Add the startup code to my project.
    Locate the interrupt vectors (uVision Version 2)...
    1. Select Options for Target from the Project menu.
    2. Select the C51 tab.
    3. Check the Interrupt vectors at address checkbox.
    4. Change the offset to 0x8000.
    Specify the code area for the linker (uVision Version 2)...
    2. Select the Target tab.
    3. Change the EPROM starting address to 0x8000.
    Rebuild my program and check the M51 map file as:
    BL51 BANKED LINKER/LOCATER V5.03, INVOKED BY:
    C:\KEIL\C51\BIN\BL51.EXE STARTUP.obj, TEST.obj TO TESTMON CODE (0X8000-0XFDFF) XDATA (0XFF00-0XFFFF)
    MEMORY MODEL: LARGE
    INPUT MODULES INCLUDED:
      STARTUP.obj (?C_STARTUP)
      TEST.obj (TEST)
    LINK MAP OF MODULE:  TESTMON (?C_STARTUP)
                TYPE    BASE      LENGTH    RELOCATION   SEGMENT NAME
                * * * * * * *   D A T A   M E M O R Y   * * * * * * *
                REG     0000H     0008H     ABSOLUTE     "REG BANK 0"
                IDATA   0008H     0006H     UNIT         _IDATA_GROUP_
                IDATA   000EH     0001H     UNIT         ?STACK
                * * * * * * *   C O D E   M E M O R Y   * * * * * * *
                        0000H     8000H                  *** GAP ***
                CODE    8000H     0003H     ABSOLUTE
                CODE    8003H     0051H     UNIT         ?PR?MAIN?TEST
                CODE    8054H     003DH     UNIT         ?PR?_DELAY?TEST
                CODE    8091H     000CH     UNIT         ?C_C51STARTUP
    OVERLAY MAP OF MODULE:   TESTMON (?C_STARTUP)
    SEGMENT                          IDATA_GROUP
      +--> CALLED SEGMENT          START    LENGTH
    ?C_C51STARTUP                  -----    -----
      +--> ?PR?MAIN?TEST
    ?PR?MAIN?TEST                  0008H    0002H
      +--> ?PR?_DELAY?TEST
    ?PR?_DELAY?TEST                000AH    0004H
    SYMBOL TABLE OF MODULE:  TESTMON (?C_STARTUP)
      VALUE           TYPE          NAME
      -------         MODULE        ?C_STARTUP
      C:8091H         SEGMENT       ?C_C51STARTUP
      I:000EH         SEGMENT       ?STACK
      C:8000H         PUBLIC        ?C_STARTUP
      N:0000H         SYMBOL        IBPSTACK
      N:0100H         SYMBOL        IBPSTACKTOP
      N:0080H         SYMBOL        IDATALEN
      C:8094H         SYMBOL        IDATALOOP
      N:0000H         SYMBOL        PBPSTACK
      N:0000H         SYMBOL        PBPSTACKTOP
      N:0000H         SYMBOL        PDATALEN
      N:0000H         SYMBOL        PDATASTART
      N:0000H         SYMBOL        PPAGE
      N:0000H         SYMBOL        PPAGEENABLE
      D:0081H         SYMBOL        SP
      C:8091H         SYMBOL        STARTUP1
      N:0000H         SYMBOL        XBPSTACK
      N:0000H         SYMBOL        XBPSTACKTOP
      N:0000H         SYMBOL        XDATALEN
      N:0000H         SYMBOL        XDATASTART
      C:8000H         LINE#         81
      C:8091H         LINE#         88
      C:8093H         LINE#         89
      C:8094H         LINE#         90
      C:8095H         LINE#         91
      C:8097H         LINE#         140
      C:809AH         LINE#         141
      -------         ENDMOD        ?C_STARTUP
      -------         MODULE        TEST
      C:0000H         SYMBOL        _ICE_DUMMY_
      D:0090H         PUBLIC        P1
      C:8003H         PUBLIC        main
      B:0090H.5       PUBLIC        green_led
      B:0090H.4       PUBLIC        red_led
      C:8054H         PUBLIC        _delay
      -------         PROC          MAIN
      -------         DO
      I:0008H         SYMBOL        i
      -------         ENDDO
      C:8003H         LINE#         12
      C:8003H         LINE#         13
      C:8003H         LINE#         28
      C:8005H         LINE#         29
      C:8007H         LINE#         31
      C:8007H         LINE#         32
      C:8007H         LINE#         33
      C:800DH         LINE#         34
      C:800DH         LINE#         35
      C:800FH         LINE#         36
      C:8016H         LINE#         38
      C:802CH         LINE#         40
      C:8040H         LINE#         41
      C:8040H         LINE#         42
      C:8042H         LINE#         43
      C:8049H         LINE#         45
      C:8053H         LINE#         46
      C:8053H         LINE#         48
      C:8053H         LINE#         49
      -------         ENDPROC       MAIN
      -------         PROC          _DELAY
      D:0006H         SYMBOL        t
      -------         DO
      I:000AH         SYMBOL        q
      I:000CH         SYMBOL        m
      -------         ENDDO
      C:8054H         LINE#         51
      C:8054H         LINE#         52
      C:8054H         LINE#         55
      C:806CH         LINE#         56
      C:806CH         LINE#         57
      C:8072H         LINE#         58
      C:8072H         LINE#         59
      C:8083H         LINE#         60
      C:808DH         LINE#         62
      C:8090H         LINE#         63
      -------         ENDPROC       _DELAY
      -------         ENDMOD        TEST
    Program Size: data=15.0 xdata=0 code=157
    LINK/LOCATE RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
    What else should I do?
  • What else should I do?
    Modify the settings for the debugger so that it loads the application but so taht it does not run til main.
    Then, start the debugger.
    Enter $=0x8000 in the command window.
    This should show your program's disassembly in the source window.
    Jon
