Anybody know how to view .lib file for UV2? It is important when I want to implement the functions in the .lib for my project. Thanks a lot Dragon
If you're implemnenting the .lib then you already have the source file(s)! You just check the 'Create Library' box in the 'Output' tab of your Project Options to tell it to create a Library instead of an "executable" You will also need to read the Library Manager Manual
