Hello, Everytime I set a breakpoint in UV2 (for Cygnal chips), run, then try to halt the program before hitting the breakpoint, UV2 becomes unresponsive and has to be killed by process manager. I've seen the problem on Windows XP,NT and W98. Anyone seen this problem or have a work-around? Thanks, Chuck
Are you using the latest version of the C51 tools?
I'm using UV2: 2.31.
"I'm using UV2: 2.31." that'll be a "No", then! Presumably, there's a driver DLL from Cygnal? Make sure you've got the right one of them, too (ask Cygnal).
So not crashing is a cutting edge feature found only in the latest version. Cool! I'll shell out thousands more. No thanks.
Have you downloaded the latest Cygnal driver (maintained by Cygnal) which is available for FREE from the Cygnal web site? The URL on the Cygnal web site is: http://www.cygnal.com/support/keildriver.htm Jon
I've the same problem for 4 months.I flawed the Cygnal with 20 mails, but they are still "working on problem".It seems they do not know, where the problem is. Can somebody(maybe Keil) push on them?
