Hi, I'm working with the MCB167-NET application board and the aplication note APNT-164. My problem is this: I would like, that the dinamic values of this examples, that comes from the A/D converter of the micro, will be able to be saved in a file, for example an excel or word file. The reason of this is that I want to create a data base that contains all of the data that the web serves. I don't know if a Html code can do it,but I would like to do it with a C function. Note: This values must be saved automatically without any user must to press any button. Can somebody help me? Thanks . Sergio.
I would change the HTTPServer() to send a HTTP header like this(instead of the html-file): Content-type: application/vnd.ms-excel Content-Disposition:attachment filename=DataExport.csv Expires: 0 Cache-Control: must-revalidate, post-check=0,pre-check=0 Pragma: public This would force the calling browser to prepare for an incoming file. Now you can send the values and seperate them by ';'. Now you should get an CSV file which can be viewed with excel.
