I have a question , please show me command " MOVX @RI,A" in C51 ! I can't to find , please help me ! thanks very much !
stmt level source 1 void movx(unsigned char pdata *p, unsigned char b) 2 { 3 1 *p = b; 4 1 } ASSEMBLY LISTING OF GENERATED OBJECT CODE ; FUNCTION _movx (BEGIN) ; SOURCE LINE # 1 ;---- Variable 'b' assigned to Register 'R5' ---- ;---- Variable 'p' assigned to Register 'R0' ---- 0000 A807 MOV R0,AR7 ; SOURCE LINE # 2 ; SOURCE LINE # 3 0002 ED MOV A,R5 0003 F2 MOVX @R0,A ; SOURCE LINE # 4 0004 22 RET ; FUNCTION _movx (END)
"MOVX @RI,A" in C51 ! I can't to find" Of course you can't - it's assembler; not C!!! As Dan has shown, you need to use the pdata keyword extension - but be sure to read the Manual (Chapter 3, Language Extensions), and the Knowledgebase, as there are some important provisos to pdata usage!
ok ! thanks
