EEPROM 93c46 with 89c51
I am looking for example(s) on writing/reading EEPROMs (93c46) using 89c51 in C.
Any help shall be higly appreciated.
Mansoor
  • void chngestate(unsigned char command)
    {unsigned char i;
    cs=0;//chip select
    Din=0;//In
    CLK=0;//Clock
    CLK=0;
    cs=1;
    Din=1;
    CLK=1;
    CLK=0;
    for (i=0;i<7;i++)
    if (command&0x80)
    Din=1;
    else
    Din=0;
    CLK=1;
    command<<=1;
    CLK=0;
    buf<<=1;
    if (command&0x80)
    Din=1;
    else
    Din=0;
    CLK=1;
    cs=0;
    _nop_();
    _nop_();
    int eeread(unsigned char address)
    unsigned int result=0;
    unsigned int c=0x8000;
    unsigned char i,buf;
    buf=address&(0xbf)|(0x80);
    cs=0;
    Din=0;
    CLK=0;
    CLK=0;
    cs=1;
    Din=1;
    CLK=1;
    CLK=0;
    for (i=0;i<8;i++)
    if (buf&0x80)
    Din=1;
    else
    Din=0;
    CLK=1;
    buf<<=1;
    CLK=0;
    Din=0;
    //16 bit read msb first
    for (i=0;i<16;i++)
    CLK=1;
    if (Dout) result|=c;//out
    CLK=0;
    c>>=1;
    CLK=1;
    cs=0;
    Din=0;
    return(result);
    void eewrite(unsigned int dat,unsigned char address)
    { unsigned int buf1=dat;
    buf=address&(0x7f)|(0x40);
    cs=0;
    Din=0;
    CLK=0;
    cs=1;
    CLK=0;
    Din=1;
    CLK=1;
    CLK=0;
    for (i=0;i<8;i++)
    if (buf&0x80)
    Din=1;
    else
    Din=0;
    CLK=1;
    buf<<=1;
    CLK=0;
    //send 16 bit data msb first
    for (i=0;i<15;i++)
    if (buf1&0x8000)
    Din=1;
    else
    Din=0;
    CLK=1;
    buf1<<=1;
    CLK=0;
    if (buf1&0x8000)
    Din=1;
    else
    Din=0;
    CLK=1;
    Din=0;
    cs=0;
    _nop_();
    _nop_();
    cs=1;
    _nop_();
    _nop_();
    while (Dout!=1);
    cs=0;
    _nop_();
    _nop_();
  • Thanks for the reply.
    What about 8 bit mode?
  • Hi Mansoor,
    If you don't care about the overhead, I think you can use the following method to implement your own 8-bit read/write.
    #define S_CONST_EEPROM_START_ADDR	0x01	// 0x01 ~ 0x3f
    #define GET_HIGH(xx)		( (BYTE) ((xx) >> 8) )
    #define GET_LOW(xx)			( (BYTE) ((xx) & 0x00ff) )
    // Function name  : EepromWriteOneByte
    // Description 	  : Eeprom Write One Byte through Driver
    // Return Value   :
    // [#05]
    BYTE EepromWriteOneByte(BYTE pos, BYTE byteValue)
    	BYTE cAdr, cResult;
    	WORD sData, sDataOut;
    	// write out a word
    	cAdr = S_CONST_EEPROM_START_ADDR + pos / 2;
    	vWriteDisable();
    	sDataOut = sReadWord(cAdr);  // Address from 0x00 to 0x3F
    	if (pos % 2)
    		sData = (GET_HIGH(sDataOut)<<8) | byteValue;	// odd
    	else
    		sData = GET_LOW(sDataOut) | (byteValue << 8);	// even
    	vWriteEn();
    	cWriteWord(cAdr, sData);
    	vWriteDisable();
    	cResult = EepromReadOneByte(pos);
    	return cResult;
    // Function name  : EepromReadOneByte
    // Description 	  : Eeprom Read One Byte through Driver
    // Return Value   :
    // [#05]
    BYTE EepromReadOneByte(BYTE pos)
    	BYTE cAdr, cResult;
    	WORD sDataOut;
    	// read back check
    	vWriteDisable();
    	if (pos % 2)
    		cResult = GET_LOW(sDataOut); // odd
    	else
    		cResult = GET_HIGH(sDataOut); // even
    	return cResult;
  • What do you mean by overheads. Thanks for your efforts in answering my query.
    Mansoor
  • I have just completed the project. Thanks for all who helped. I have tried to develop generalize routines for reading/writing in 8 bits.
    Any body interested,Pl. contact me on mansoork38@hotmail.com.
    Mansoor
