Hi, I'm using CYGNAL F020, I'm trying to communicate with a I2C LCD wich has 0x50 slave adress. I looked at "Cygnal I2C Example Programs" but its not functional. I'm locked up waiting for while (BUS_BUSY); in the I2C_init, why ??? My SYSCLK is 22118400 so for 50 000 bps I have loaded SMB0CR = -221; also I just modified the void write_byte (unsigned char data_out, unsigned int address) { i2c_start(); // Send start signal i2c_write(address); // Send identifier I2C address i2c_write(data_out); // Send address to EEPROM } Does anyone have an Idea or some sample code that works. I just need to send an adress and a byte of data. Thank you,
If the bus is always busy, you probably forgot to fit some pullup resistors to SCL and SDA.
Hi, I've put 2.4K and I also tried 10K pull up resistor. Both are doing the same. Any other suggestions ?
A two-channel digital sampling oscilloscope and a debugger will help a lot.
