Inline Functions
How can a write a inline function ?
Thanks Michael !
  • When used with the extended in-line assembler the Keil C16x/ST10 C Compiler allows you to create in-line functions that generate the same efficient code as intrinsic functions.
        1         typedef unsigned char  BYTE;
        2         typedef unsigned int   WORD;
        3
        4         typedef struct cla  {
        5           unsigned char  type;
        6           unsigned char  mode;
        7           struct cla    *p[2];
        8         } CLA;
        9
       10         CLA  cl1;
       11         BYTE  type, mode;
       12         CLA    *pL,  *pR;
       13         int     it;
       14
       15         __inline int Getit (CLA *pthis)  {
       16  1        int   n1;
       17  1        if (pthis->mode == 2)  {
       18  2          n1 = pthis->p[0]->mode | pthis->p[1]->mode;
       19  2        }
       20  1        else  {
       21  2          n1 = pthis->p[0]->type & pthis->p[1]->type;
       22  2        }
       23  1        return (n1);
       24  1      }
       25
       26         __inline BYTE GetMode (CLA *pthis)  {
       27  1        return (pthis->mode & 0x0F);
       28  1      }
       29         __inline BYTE GetType (CLA *pthis)  {
       30  1        return (pthis->type & 0x08);
       31  1      }
       32         __inline CLA *GetNodeL (CLA *pthis)  {
       33  1        return (pthis->p[0]);
       34  1      }
       35         __inline CLA *GetNodeR (CLA *pthis)  {
       36  1        return (pthis->p[1]);
       37  1      }
       38
       39         int near iLocal;
       40
       41         __inline WORD Mul2 (WORD w)  {
       42  1        if (w >= 0x10)  {
       43  2          __asm  {
       44  2            MOV    R4,w
       45  2      al1:  MOV    R5,iLocal
       46  2            ADD    R4,R5
       47  2            mov    w,R4
       48  2          }
       49  2        } else w <<= 10;
       50  1        return (w);
       51  1      }
       52
       53
       54         void main (void)  {
       55  1        CLA   *p1;
       56  1
       57  1        it = Mul2 (cl1.mode);
       58  1        p1 = &cl1;
       59  1        type = GetMode (p1);
       60  1        mode = GetType (p1);
       61  1        pL   = GetNodeL (p1);
       62  1        pR   = GetNodeR (p1);
       63  1        it   = Getit (&cl1);
       64  1      }
    Jon
