Hello, I am running NT4(service pack 6) using the DOS shell cmd.exe. I am trying to invoke the C51 compiler version 5.5 (8051 Development Tools) using the gnu make utility version 3.79.1. I have set up a simple makefile to attempt to make a single object from a c file containing an empty main function. ---------------------------------------- # Test makefile test1.obj: test1.c c51 test1.c clean: del *.obj del *.lst ---------------------------------------- main() { /* this is a test file */ } ---------------------------------------- The make utility tries to invoke the compiler but gets somehow interrupted and nothing happens, and the prompt is returned. Even more strange is the actual properties of the dos window seem to be magically changed during this process too, the height of the screen memory buffer reverts back to 50 lines from the 500 I initially set it to. This all works perfectly when using win98 and win2000 machines and has also had the same failure on other NT machines with different user profiles. When the compiler is invoked directly from the command line it runs fine, only when called from gnu make. When the compiler is invoked from nmake it also works fine and when gcc is used in place of the keil compiler with gnu make it also works fine. It appears it is only the combination of the C51 compiler with gnu make that causes the problem, and only NT machines. It feels like some kind of memory violation to me. Has anybody come up against this before? Is there a work around or will I just have to use a more compatible OS? Regards, Alan
can you run C51 direct from the command line - without make - on NT. If you have a dongled versino, have you installed the dongle driver properly?
"versino" Or maybe "version" ;-)
yes, c51 runs fine direct from the command line, without make on NT. The version of c51 I'm using required a registration number on installation, then runs without dongles. It seems to be the specific combination of NT, gnu make and C51 that causes the problem. short summery: WinNT, gnu make, C51 : failed (with strange effects) WinNT, nmake, C51 : worked WinNT, gnu make, gcc : worked Win98, gnu make, C51 : worked Win2000, gnu make, C51 : worked regards, Alan
Recent scientific discoveries have proven that versinos oscillate between several different versions on their way from the factory to your hard drive. The version actually captured by the bits on your disk may or may not be the same as the version originally generated. Perhaps this effect has something to do with your problem. That's what I plan to tell my boss the next time he asks why I'm not producing as much output as expected, anyway.
I'm not sure if mine will buy that.
You say you're running "GNU make", but you're leaving out one piece of information that's every bit as important as the version number of GNU make: what compiler that version of GNU make was built with. The symptoms suggest that it might well be the DJGPP version, which is a *DOS* program at it very heart. You might to better with the Cygwin or MinGW32 ports. ... and maybe show actual error messages next time...
Not sure what the compiler was - my colleague thinks it probably was DJGPP. I'm going to look into that and try using the other two ports you mentioned. There were no error messages produced, it seemed like the thread was suddenly terminated. If I run make –d it shows everything happening as it should then the messages suddenly stop in the middle. If I pipe the debug output to file it gets all the way to the c51 test1.c command, but nothing happens and the command prompt returns. Thanks, Alan
