Hello! I have written a program using the µVision/51 evaluation for Windows Version 1.24. I want to create a hex file that could be loaded in the on-board Flash of an AT89C51 by Atmel. The size of the code is expected to be less than 1 kilo byte. Would somebody tell precisely what options should I use for the C Compiler and the linker available in the above said IDE.
As it's your first project, you're using an evaluation version, and your code's under 1K, why are you starting off with an out-of-date product? Why not get the current evaluation version - which is still free!?(download, or request CD) It comes with some example projects - it'd be worth working through them first.
Please guide me that how can i get free cd or any material through internet
"Please guide me that how can i get free cd or any material through internet" You will need to put in some work, and use some initiative: start by clicking the 'Products' link at the top of the page...! Once you get your CD and/or download, be sure to read the uVision Getting Started Guide, and work through the example projects in it. This will give you a proper introduction to the tools.
