Hi , I am not sure if my question is relavent to this forum or not but its an interesting programing prblem that i am facing. I hope someone here would be able to give usefull advice on it. my microcontroller is receiving a stream of data of 25bits. The stream is 0000011100000001000111000. These bits are encoded strangely. A zero appears as follows, (please ignore the dots, they are just there to hang the pattern.) ___ |...| |...| |...| |...|________ The ratio of high-time to low-time is 1:3. while one appears as follows: ________ |...........| |...........| |...........| |...........|___ The ratio of high-time to low-time is 3:1. My question is that what is this encoding scheme, and how can i read this in a microcontroller ?? I am receiving this stream on a normal pin which is not an interrupt pin. I am looking for some neat algorithm to read the stream faithfully. Any help would be great; thankz & Bye .
You shoudl rather try the newsgroup comp.arch.embedded
"(please ignore the dots, they are just there to hang the pattern.)" You need a monospaced (fixed-pitch; not proportional) font to do ASCII-art. This can be achieved with the <pre> and </pre> tags (standard HTML); eg,
I'm not sure of the terms but this is a self-clocking code similar to the old Tarbell cassette scheme from the late 70's. You have to sample the pin periodically with a period smaller than the narrowest pulse. This guarantees a sample (possibly more) in each narrow state. You record the number of high samples and the number of low samples. At the first high reading, you decode the last bit and reset both counters. If the high count is larger than the low count you have a '1', otherwise a '0'. You can also save time and space by counting up on high samples and down on low samples. A bit is a '1' until the count <= 0. It usually pays to sample at a much higher rate to account for signal degradation.
---- ------------ --- signal ------------ ---- sample points | | | | | | | | | | | | values 1 1 2 3 4 1 2 3 4 1 2 output - - - - <-0 - - - - <-1
Pulse-width encoding... Detect the rising (leading) edge of a bit and then either sample at a point that is half way between the width of a 0-pulse and the width of a 1-pulse, or detect the falling edge and check the pulse width. Repeat for all bits. --Dan Henry
This looks very similar to RS232 communications. It looks like there is a start bit, a redundant data bit, and a stop bit. A timer interrupt could do the sampling. Some of the commercial UARTs use 16 clocks per bit. Once they find the edge of the start bit, they sample the value of the bits in the center. The majority of the three bits in the center of the bit could define the value of the bit. I'd guess that this is synchronous data, rather than asynchronous, so part of the challenge is to separate the start and stop bits from the data.
