How determine library sizes?
In LST files you can find totals about module memory usage, in M51 you can do the same for complete application but, how can I determine the memory usage (code and data)when I build a library ?
Talking about building libraries, are there any inmediate method or utility to determine the maximum function call level and so avoid stack problems?
Thanks in advance
Javier
