Whenever ,an external data memory is accessed, by using DPTR, the corresponding DPL and DPH values has to be appear in the Low order address bus (PO) and high order address Bus(P2). As per the following programme
#include<reg51.h> 2 3 unsigned char xdata temp _at_ 0x8000; 4 void main( void) 5 { 6 1 while(1) 7 1 { 8 2 9 2 P0=0X88; 10 2 P2=0X88; 11 2 temp=0xf0; 12 2 P3=temp; 13 2 } 14 1 }
The P0 and P2 are just registers, they are not equal to ports. During the mcu read cycle, the ports are drived by the internal address bus or the data(P0 port) bus, they are not connected to the P0 and P2 registers. Pls download a 8051 datasheet, you will get the answer.
You may be surprised to note that the Keil Simulator does not simulate the RAM signalling process. For example, ALE does not toggle, /RD and /WR don't wiggle either. Why is that, you may ask? Well, uVision2 doesn't simulate to that level of granularity because it doesn't need to. If that were a part of uVision2, then YOU would have to define what you want to happen when ALE wiggles. And that defeats the idea of having a simulator that runs fast and that is fast to start using. Actually, if you need to see /RD, /WR, ALE, and other signals wiggle, then you are really looking for a full-up SPICE simulation of your hardware. If that's what you need, take a look at the following URL. http://www.keil.com/pr/labcenter_010320.htm These guys have integrated their SPICE model with uVision2 to give you the best of both simulation worlds. Jon
