Dear Sir! I am unable to use an initialised array. The array gets initialised but whn it is used in a function it does not give the proper values. What could be the reason. Please tell me.
Can you post an example?
There are 2 possible reasons: 1. a coding error; 2. a hardware bug in your target. To help you with your code, we'd have to see it! Can you post a small sample which illustrates the problem (not forgetting to use those <pre> and </pre> tags - see "Tips for Posting Messages") To check against hardware problems, does it work properly in the simulator?
