With Keil uv2, I create a new project, then select the device W77e58, But when I use the additional instruction, the Keil's 8051 toolchains can not work, it say that no such instruction. Why???? Thanks for your help!
The DEC DPTR instruction is not a standard 8051 instruction. You'll have to create a MACRO to implement this instruction using a DB. Jon
Thank you. I know how to create and use a MACRO. But I still can not understand why this extended instruction is not included in keil's toolchains. Thanks again.
Yes, I thought that Keil'w wonderful "Device Database(TM)" was supposed to cope with all the different features of all the different processor variants. So, apparently, it only copes with different sets of on-chip resources; not with extended instructions?
The REAL problem is that there are many more than 1 extra instructions that use the A5 unused opcode. None of them are standard and none of them is portable to other chips. So, rather than create 100 or so new directives that allow support 100 or so "new instructions" we thought it was just as easy to require the user to create a 3 line macro to do the same thing. Jon
Thanks to all
