We have written a 'C' file with SRC directive .After compiletion with Uv2 (with out including Startup.a51) a .SRC file is generated as usual.How do we set the starting address of the same file accoriing to our wish eg. the starting address of the file may be 0x300. We tried about setting code address trough option through target in target option. Then we change in the l51 -locate optin to give the desirable address for on chip code memory. It is not working. Please guide us.
You can set start addresses of segments, not files. This is explained in the A51 User's Guide, Chapter 9 Linker/Locater under Segment and Memory Locating Controls.
