v6.20 problem?
Has anyone else tried C51 v6.20/uVision v2.20?
In one of my 'C' source files with inline assembler, the new Compiler
now creates an empty DATA Segment in the generated assembler. This
causes the Link to fail with Error L109, "Empty Relocatable Segment"
According to the online help & the PDF manual, L109 should not be a
fatal error; the Segment should simply be ignored.
So there are two issues here:
A. Why does the new compiler generate the empty Segment?
B. Why does the BL51 Link fail, when this should not be a Fatal error?
(the behaviour is the same for both the v4.14 & v4.20 Linkers).
  • I am currently experiencing exactly the same problem. The compiler is adding additional lines to my .a51 file and as you say, the linker is complaining. A temporary (but not good) fix is to remove the unwanted lines. The output file can then be built as normal. Have you had a solution from Keil? I would be grateful if you could pass on any information.
  • Does anybody have a solution for this Non-fatal error L109 of v6.20. Shall be gratefull, if you could share the information.
  • I have sent this info through to Keil for an answer...
    I am currently using the Keil compiler C51 (V6.23a) and linker BL51 (V4.23).
    I recently upgraded to this version of compiler and linker and am now getting the 'Error L109, "Empty Relocatable Segment"' error on a file that was previously compiling and linking perfectly.
    The Problem:
    I have a file with the following compiler settings selected "Generate Assembler SRC File" & "Assemble SRC File". What I see the problem code being is as follows:
    static void GenFac (unsigned char xdata *key, unsigned char xdata *fac_ptr) small
      unsigned char xdata fac[8];
      unsigned char i=0,j=0;
    This code generates the following empty relocatable segment in the SRC file:
    ?XD?SMGF_Request?REQSMGF           SEGMENT XDATA OVERLAYABLE
    ?XD?_GenFac?REQSMGF                     SEGMENT XDATA OVERLAYABLE
           EXTRN         XDATA (cvt_conversion_error)
           RSEG  ?DT?_GenFac?REQSMGF
    ?_GenFac?BYTE:
           key?040:      DS   2
           fac_ptr?041: DS   2
           fac?042:       DS   8
    This SRC file is created with OT set to 8 but the above problem is still present with OT set to 0. Why does the compiler take the liberties to change the data segment type of the local variable, am I missing something? I am assuming that this is both a compiler & linker problem:
    1) The compiler should not be changing the segment space type of variables (it has no idea about the project's global data space usage &
    2) The linker should pick up on this problem but should not stop linking (i.e. should not be a fatal error)? A warning at the most?
    I have solved this problem for the moment by removing the xdata segment space type from the variable declaration. It work just as well with "data" in place of "xdata" for obvious reasons.
  • I have found the reason for this problem I have been having. I noticed that the function was declared with the directive small (small memory model):
    This means that the new compiler is making all the functions local variables "data space variables" as per the functions directive, but the declaration for the variable itself is creating an xdata segment.
    What then did the previous version of the compiler do?
    1) My guess is that it made the variable a data variable and did not create the xdata segment - and did not produce a warning / error that it was doing this?!? The linker would not have been able to pick that up since there was no (empty) xdata segment created...
    2) Alternatively the compiler made the variable xdata? So why only in the new compiler does it abide by these rules?
  • I have a large code settings for my project.
    The following code generated L109 error:
    typedef union tagLONGLONG{
    struct{
    unsigned short hi;
    unsigned long lo;
    } LL;
    unsigned char bytes[6];
    unsigned short words[3];
    } LONGLONG;
    void ZeroLONGLONG(LONGLONG xdata *v)
    v->LL.hi=0; v->LL.lo=0;
    This fix shuts down the error:
    char xdata i; //dummy fix
