Strings and arrays
Hello people,
My question is C langage use.
I'd like to define a list of strings and to compare this list with a string incoming from the UART in order to build a command line interpreter.
The string from the UART is saved in a buffer. Let's name it au8TextBuffer.
The problem is that I can't do a
switch (au8TextBuffer)
   case "abc": ...
   case "def": ...
because the compiler returns an error. The switch function seems to not point on arrays
I could declare the strings in an 3D array
U8 au8text[3][3] = {"abc","def","ghi"};
but how to point on this array ?
I've seen on the web a method with structures, but it doesn't work :
#define CMD_TBL_LEN (sizeof (cmd_tbl) / sizeof (cmd_tbl [0]))
enum
	CMDID_HELP,
	CMDID_SETVAR,
	CMDID_ENDLIST
struct u8CommandString {
  	unsigned char *u8String;
  	unsigned char u8Identifier;
static struct u8CommandString CommandTable[] =
    	{ "HELP",	CMDID_HELP},
    	{ "SV",	CMDID_SETVAR},
U8 Cmdid_Search (U8 *u8String)
	struct u8CommandString *ctp;
	for (ctp = CommandTable; ctp < &CommandTable[CMD_TBL_LEN]; ctp++)
  		if (strcmp (ctp->u8String, u8String) == 0)
  			UART_Printf("reussi !!!!!");
  			return (ctp->u8Identifier);
	return (CMDID_ENDLIST);
The 'if (strcmp (ctp->u8String, u8String) == 0)' never works. I've tried to monitor on hyperterminal the ctp->u8String, but it displays irrelevant characters...
Any suggestion or link to browse ?
Stephane
