Every time I exit and re-enter debug in uV2 I have to re-select all of my Peripherals windows. Is it possible to have them re-open automatically?
The position of peripheral dialogs is usually automatically stored. They are also opened automatically at the same place. - What derivative did you select for your target in uVision2? - Are you using the simulator or target debugger?
In one application I use Intel 80C51BH, in the other Intel 83/87C51RA I'm using the simulator. "Restore Debug Session Settings" has *everything* checked. I don't lose watchpoints.
What version are you using? From about V7.01 all dialogs are saved and reopned each entry into Debugger. Of course watch points are not saved because of scope but you can review the Locals window.
Maybe you can try the following link: http://www.keil.com/forum/docs/thread1983.asp I had more or less the same question some time ago. Jon answered me and gave some good hints. --Geert
version 7.01? I'm using a program purchased a couple of years ago - uV2 version number is 2.10. The compiler version is 6.10.
uV2 version number is 2.10 You probably need a more recent version of uVision2. When you license the tools, you receive 1 year of support and product updates. Check the updates on this web site ( http://www.keil.com/update ) and download something more recent than 2.10. Jon
Looks like I can't update. Out of the support period. I guess I'll have to live with it. Thanks, Scott Kelley scottk@iccom.com
