Hi,First of all, Merry Christmas! I got a problem with the little function below: I just try to display an unsigned long variable on a 6 digits LCD (I know, I m not going to be able to display the whole number)Everything works fine from 0 to 69999 but there is a problem from 70000 to 100000 and then it works fine again. I would understand if the problem happens after 65535 but...no... Thank you for any idea, sorry for my English an , again, Merry Christmas!
unsigned long count; unsigned char tab[8]; void compt_to_digit_4b(unsigned long count_4b, unsigned char *tab_compt) { unsigned char centmillier; unsigned char dimillier; unsigned char millier; unsigned char centaine; unsigned char dizaine; unsigned char unite; unsigned char dixieme; unsigned char centieme; //unsigned char incr_x; /*for(incr_x=0; incr_x<8;incr_x++) { tab_compt[incr_x]= 0x00; } */ centmillier=0; dimillier=0; millier=0; centaine=0; dizaine=0; unite=0; dixieme=0; centieme=0; //if(ind==1) //{ centmillier=(unsigned char)(count_4b/10000000); tab_compt[0]= centmillier; count_4b=(count_4b - (unsigned long)(centmillier*10000000)); dimillier=(unsigned char)(count_4b/1000000); tab_compt[1]= dimillier; count_4b=(count_4b - (unsigned long)(dimillier*1000000)); //} millier=(unsigned char)(count_4b/100000); tab_compt[2]=millier; count_4b=(count_4b - (unsigned long)(millier*100000)); centaine=(unsigned char)(count_4b/10000); tab_compt[3]= centaine; count_4b=(count_4b - (unsigned long)(centaine*10000)); dizaine= (unsigned char)(count_4b/1000); tab_compt[4]=dizaine; count_4b = (count_4b - (unsigned long)(dizaine*1000)); unite= (unsigned char)(count_4b/100); tab_compt[5]= unite; return; } void main(void) { compt_to_digit_4b(70000,tab); }
The following code works just fine:
#define LCD_LEN 8 unsigned char tab[LCD_LEN]; void compt_to_digit_4b ( unsigned long count_4b, unsigned char *tab_compt) { unsigned char i; for (count_4b, i=LCD_LEN; i>0; i--, count_4b/=10L) { tab_compt[i-1] = count_4b%10L; } } void main(void) { compt_to_digit_4b(70000L,tab); compt_to_digit_4b(12345678L,tab); compt_to_digit_4b(98765L,tab); while (1); }
Wow wow wow wow! Thank you very much Jon!! Everything works fine now. I just wonder why my code was wrong. I guess it's just not the right way to do this. If somebody got some time to tell me why, I would be really happy! Anyway, I wish you a merry Christmas! Mine is going to be better due to you! Thanks again! Arnaud Stoumont
