? C51: USING THE ON-CHIP XDATA OF THE INFINEON C515C
Hi:
I find the same question I meeted.
But I don't understand the content as followed...
3. Add the following instruction (ANL 0B1h, #01h) at the beginning of the startup code (BEFORE XDATA is cleared).
ANL 0B1h, #01h ???
Thanks for any reply.
  • Whoa!
    You seem to have just posted something completely out of comtext from an ongoing discussion!
    ANL 0B1h, #01h
    looks like a perfectly ordinary line of assembler - what don't you understand about it?
  • Probably refer to clearing a bit in a SFT that control the source of XDATA for the addresses where external and internal XDATA both exist. (internal XDATA, do'nt you love it) I suggest EDATA for extended data as the name for this.
    Now my question: you have an existing design with external RAM mapped from 0000. To gain a bit more RAM withou modifying the hardware, you pop a chip with some EDATA memory in. QUESTION: How do you define which variables are in XDATA and which in EDATA since the addresses are the same - and how do you specify the switch the thread originatot talks about (I know that e.g. Winbond and Philips use different mechanisms).
    Have fun,
