Hi all, I have a program which runs perfectly on a 8951 based system. When I write the same program to a 8952 to run on the same system, the system does not function as before. It starts to fail to interpret the if statements as before. Is there any change which I must do to move to 8952? Any code change, any compiler/linker option? Regards,
