NO_INIT data area
I am converting from the IAR compiler to Keil and cannot find reference to defining segments like I used to. Specificly I used a seg known as NO_INIT in XDATA for variables I did not want altered on power up.
Any help would be great.
  • This is common among many compilers, but I don't think that Keil actually has such a notion?
    Are you trying to implement some sort of non-volatile memory?
    It sounds like you've probably already searched the Compiler & Linker manuals for suitable options.
    The file startup.a51 controls the initial clearing of XDATA, etc - could you modify this to give an uninitialised area, and then use Linker controls to put your non-volatile variables into that area?
    See Chapter 6, "Advanced Programming Techniques" in the C51 User's Guide
  • Correct, I am working on getting a non-volatile area defined that does not get initialized on start-up. A place I can drop variables that remain intact.
