Thanks to Andy Neil, I got my commandfile to run and everything is cool except that I do not get the "console file" c.d in the above example. Until I switched to the @ format, I got the file and printed it conditionally on an errorlevel test which is a nice way of doing things as far as I'm concerned (no messages, it's cool - messages, check it). Does anyone have any idea as to the above problem? Happy memorial day Erik
My guess is that using the @commandfile prevents BL51 from writing anything to the console; This would make sense in the case where BL51 is invoked automatically by something like uVision, where there is no console window to receive any output! Therefore, if you want the messages, you'll have to specify a PRINT control to put them in a file? You could still test the ERRORLEVEL, and then do something like this to display the messages if it indicates problems:
BL51 @commandfile IF NOT ERRORLEVEL 1 GOTO :success find "*** WARNING" listfile :success
