Does anyone have a good methodology for keeping things separate with 2 '51s having p0/p1/p2 tied together, thus handshaking to gain access to the xram. To gain more individual ram, I plan to use chips with a k of "internal xram". I would like to know if anyone has a good method for keeping things straight in such an environment. Erik Malund
If you do not need much shared RAM and/or cost is not a vital consideration, you should consider using dual-port RAM. Dual-port RAM will make things much easier.
would have used dual-port, if I had been involved before 1000's were built. Need to take care of problems using existing HW
Assuming that you have all your hardware sorted out, what you need is a software solution to avoid simultaneous attempts to access the shared xdata. A software solution will slow processing significantly, so it is a good idea for each processor to have some xdata memory of its own. The simplest method would be to a have a couple of flags, exchanged via couple of spare port pins, allowing each processor to indicate when it wishes to access the shared xdata and to read when the other processor wishes to access the shared xdata. Each processor puts out my_flag and receives your_flag. Things are also simplified if, at any given time, one processor has priority access to the shared xdata The procedure for each processor to follow when it wishes to access the shared xdata is as follows: Wait until your_flag is clear. Set my_flag. Double-check that your_flag is clear. Complete shared xdata access. Clear my_flag. The double-check is required because it is possible that the two processors set their my_flag at exactly the same time. The double-check is resolved, by having the lower-priority processor back down and return to waiting for you_flag to clear. This sort of scheme may be integrated into your software by use of macros or function calls to access the common xdata - simply pass the address of the variable to the function or macro. Building your software presents some interesting problems. Presumably, your processors each want to share the variables placed in shared xdata. The common variables should be indicated as being volatile. You could place them manually using the _at_ keyword. If you need to do more complicated things such as allowing each processor to have its own unshared variables and even to have local, overlayed variables then you are going to have to read the manuals carefully and do some experimentation, but these things should be possible.
