ST10R172
Hi everyone!
We would like to use the debugger with our ST10R172 chip (selfmade hardware
-flash1 0x0-0x20000;
-flash2 0x300000-0x3fffff
-ram 0x100000-0x1fffff)
BUT you know in the ST10R172 there is only 1kbyte ram (FA00-FDFF), and we couldnot use the debugger because if we put the VECTAB to 0xFC00 (because SYSSTACK at FA00-FBFF) after the monitor downloaded the program it stops at FC00H where is the "JMPS owncode_address", we press F11 and the monitor doesnot jump to the codestart. it put ADD R0,R4 at FC02H.????
Any suggestion from you? Where is the mistake?
