Simulating External Bus Transactions With uVision2
Is it possible to see any external transactions in the uVision2 simulator? For example, if I map an address space to off chip and write to it in the simulator will I be able to see the Port 0 or Chip Select transitions? I understand the the VTREGS can be used for input to the Ports but will I be able to see any outputs from the micro?
