Problem Setting up PEC for Serial Comms (C167Cr)
Hi, I basically used the methodology provided by keil on this website.
I am able to set up the PEC and it transmits data out of the Rs232 port. Unfortunately it appears to be transmitting data from a different location than the one I loaded to it (it sends the first byte correctly and all other bytes are 0xFF)! This is my first attempt at using a PEC so I am sure that I am doing something wrong. Here is my code (you will see hacks in it).
void vSendSerData( BYTE *pbBuf, BYTE bLen )
Description:  This routine sends bLen bytes to the serial port transmitter,
              waiting for the port to empty before sending the next character.
Inputs:  pbBuf - Pointer to byte[s] to send
         bLen - Number of byte[s] to send
Outputs:   NONE
Globals: g_bitCommsType - Indicates Rs485 or Rs232
         g_bitCommsDir - Sets Rs485 direction (transmit or receive)
         m_bTransmitByteCount =  Transmit byte count used by trasmit interrupt
         m_bTransmitByte = Current byte to transmit
static BYTE huge jakdata[5]= "Jerk";
bLen =4;
   /* If this transmission is meant for the Rs485 bus, disable recieve
      interrupts and set the Rs485 line for transmission */
   if (g_bitCommsType == SELECT_RS485)
      ASC_vReceiverDisable();
      g_bitCommsDir = TRANSMIT_485;
   /* Set up PEC 0 (Peripheral Event Controller 0) to:
          increment the source pointer on each transfer,
          set the transfer size to a byte and
          set the number of bytes to transfer to bLen */
   PECC0 = 0x500 | (WORD)bLen;
   /* PEC source pointer is set to the next character in buffer */
   SRCP0 = _sof_(&pbBuf[1]);
SRCP0 = _sof_(&jakdata[1]);
   /* PEC destination pointer is set to serial transmit buffer register */
   DSTP0 = (WORD)&S0TBUF;
  /* enable transmit interrupt */
  /* transmit interrupt priority level(ILVL) = 14 */
  /* transmit interrupt group level (GLVL) = 0 */
  S0TIC = 0x0078;
   /* Set flag indicating that transmission isn't complete */
   m_bTxDone = FALSE;
   /* Put the first byte from the buffer into the transmitter port, PEC 0 will
      process the rest */
//   S0TBUF = pbBuf[ 0 ];
S0TBUF = jakdata[ 0 ];
   /* Wait for the PEC to finish transmitting the message */
   while ( m_bTxDone == FALSE )
      os_delay_task(1);
}/* vSendSerData() */
void vSerialTransmitInterrupt(void) interrupt SERTXINT
Description:  This is the transmit interrupt handler.  This routine is called
              when a character has been transmitted from the serial port.  The
              routine moves the received character to a recirculating buffer,
              then increments the buffer pointer.  If the buffer pointers are
              equal after the increment, the overrun flag is set.
Inputs:   NONE
Outputs:  NONE
Globals: m_bTransmitByteCount - Pointer to total transmit buffer count
         m_bTransmitByte - Pointer to current transmit buffer index
   S0TIC = 0;
   /* Transmission complete, enable receiver if necessary */
      g_bitCommsDir = RECEIVE_485;
      S0REN = 1;               /* enable the ASC receiver */
   /* Set flag indicating that transmission is complete */
   m_bTxDone = TRUE;
}/* vSerialTransmitInterrupt() */
My map file is as follows:
START     STOP      LENGTH    TYPE  ALIGN  TGR  GRP  COMB  CLASS   SECTION NAME
000000H   0001FFH   000200H   ---   ---    ---  ---  ---   * INTVECTOR TABLE *
00F800H   00FBFFH   000400H   ---   ---    ---  ---  ---   * SYSTEM STACK *
00FC00H   00FC1FH   000020H   DATA  WORD   ---  ---  ---   *REG*   ?C_MAINREGISTERS
00FC20H   00FC3FH   000020H   DATA  WORD   ---  ---  ---   *REG*   rtx_clk_rb
00FC40H   00FC5FH   000020H   DATA  WORD   ---  ---  ---   *REG*   can_isr_rb
00FC60H   00FC7FH   000020H   DATA  WORD   ---  ---  ---   *REG*   rtx_int_rb
00FC80H   00FCA5H   000026H   DATA  WORD   ---    3  PUBL  IDATA0  ?ID0?FREQINP
00FCA6H   00FCA8H   000003H   DATA  BYTE   ---    3  PUBL  IDATA0  ?ID0?FSTCOMMS
00FCAAH   00FCCDH   000024H   DATA  WORD   ---    3  PUBL  IDATA0  ?ID0?RTXPSREQ
00FCCEH   00FCCFH   000002H   DATA  WORD   ---    3  PUBL  IDATA0  ?ID0?RTXHARDW
00FCD0H   00FCDFH   000010H   DATA  WORD   ---    3  PRIV  IDATA0  ?ID0?RTXPSRQA
00FCE0H   00FCFFH   000020H   ---   ---    ---  ---  ---   * PEC MEMORY *
00FD00H   00FD07H   000008H   DATA  WORD   ---    3  PRIV  IDATA0  ?ID0?RTXSWTCH
On page 58 of the Keil C166 Compiler, I can see the following line:
The PEC source and destination pointers are used for PEC transfers and are located in the internal RAM at address 0FDE0H to 0FDFFH. This appears to conflict with the adresses in the map file.
The first line in my main.c file is:
#pragma PECDEF (0-7)
I do not use the PCDEF directive when I compile (should I)?
Any suggestions would be much appreciated.
  • Hi Brad,
    PEC can only access data within segment 0 (address range 0-0xFFFF). Make sure that transmit buffer is located in that segment, for example, use sdata memory type for transmit buffer.
    That should be enough. This pragma is there to make sure that no variables or other program data will use address range 0xFDE0-0xFDFF and corrupt PEC pointers.
    - mike
  • Mike thanx...
    Doesn't it seem as though my PEC memory is mapped to the wrong location.....?
  • According to the microcontroller manual, it's 0xFCE0-FCFF. It is a typo in the compiler manual. There are other typos, I'm sure. For instance, look at the headers on pages 13 and 15. Notice anything funny?
    Regards,
    - mike
  • Mike,
    Thanks so much for your help. It was just what I needed.
    Unfortunately, our board has no RAM (other than on-chip RAM) at addresses 0xC000-0xFFFF. I was however able able to make the system work using idata. Unfortunately, we don't have enough idata left to hold the entire transmit buffer so we may have to settle for our current system without PEC transfers. In any event, you saved me alot of headaches with your suggestion. Thank you!
  • Hold on a seond. I enabled the XRAM and now I have 8 kbytes of memory to work with. This is going to work as slick as snot!! Yehaw!!!
