Hi I just got the evaluation version of a software(yVision2) from the keil's website and every time i try to debug one of their examples it says running in eval mode, does anyone knows what the problem is?Can anyone advice me on a good( and cheap) software for programming Controller Area Networks? Looking forward to hear from you Miguel
The software says it is running in evauation mode because you haven't plugged in the dongle. You haven't got a dongle because you haven't paid for the software. If there were good AND cheap software available none of us would have bought Keil. Stefan
Hi Stefan I did not know(still not sure)that a dongle was needed in order for it to run.I was told(by a Keil member of staff)that as long as the code did not exceed 2Kbytes then there wouldnt be any problem. Do you know of any other languange that i could use to program a CAN controller? Thanx 4 ur help Adios
I just got the evaluation version of a software(yVision2) ... it says running in eval mode This message is displayed because the version you have is the evaluation version. This reminder is displayed to remind you that it is the evaluation version. It does not mean that it does not work or that it is broken. Jon
