compiler doesn't run
After installing the C51 Developers kit(DK51 V5.50 for windows) I can't get the compiler to run. I have windows NT 4. When I type C51 or c51.exe in the bin directory it pauses for less than a second then the command prompt comes back and nothing else happens. I am using an installation where a serial number is required at install time, after which no licencing files are required.
Can anyone help me?
Regards,
Alan
  • C51 V5.50 should work just fine under Windows NT4 SP4 or later.
    C51 V5.50 was a DOS program with a DOS extender. So, make sure that your DOS box doesn't disable extended/expanded memory.
    We're currently shipping C51 V7.04 and that is a Windows product. You may want to consider upgrading--V5.50 is pretty old.
    Jon
  • I got to the bottom of the problem. My path environmental variable was extremely long. After shortening it to a more sensible length, the compiler ran normally.
    The group I have joined are sticking with V5.50 – they tell me the code doesn't compile in the same way with later versions and some of our customers also use this version.
    Thanks,
    Alan
