Hi This program i am using has two different timer routines and i dont what each one of them is doing.In the first one i do not understand what is meant by the Timer Register for the high byte(TH0) and v being shifted by 8. Also for routine number 2, what is meant by SCON = 0x50; and TMOD |= 0x20 ;.Where did the value 213 for TH1 come from(TH1=213)? 1)void timer0 (void) interrupt 1 using 1 { /* Int Vector at 000BH, Reg Bank 1 */ unsigned char i; unsigned int v; TR0 = 0; // stop timer v = TL0 | (TH0>>8); v += (unsigned int) (T0_CLOCK); TL0 = (unsigned char) v; TH0 = (unsigned char) (v >> 8); TR0 = 1; // start timer 2)void main (void) { bit CanMessageReq = 0; // Remote Frame Requested // init serial interface SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 213; /* TH1: reload value for 1200 baud @ 20MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ // ToDo take timer from RTX51 Tiny #define PERIOD -500 /* 250 usec interrupt period */ /* setup the timer 0 interrupt */ TL0 = (unsigned char) (T0_CLOCK); TH0 = (unsigned char) (T0_CLOCK >> 8); TMOD = TMOD | 0x01; /* select mode 1 */ TR0 = 1; /* start timer 0 */ ET0 = 1; /* enable timer 0 interrupt */
v is a 16 bit integer, TH0 is an 8 bit register containing the high 8 bits of a 16 bit timer. So, to get the high 8 bits of v into TH0 you have to rightshift by 8, likewise to transfer the contents of TH0 into the high half of v you have to rightshift it by 8. Regarding the contents of TMOD and SCON look in the device datasheet for a full explanation. The datasheet will also show you how the reload value of TH1 is calculated for baudrate generation. Stefan
Oops! Some of that was rubbish. To transfer TH0 into the high half of v you would have to leftshift it. I think your code was doing something different, unfortunately I can't see it while typing this reply. Stefan
The line: v = TL0 | (TH0>>8); is a bit strange as TH0>>8 would always be zero. Maybe it should be TH0<<8? Stefan
hi Thanx for your help Stefan.I do not know if it is right shifting or left shifting but i will find out.One more thing, do you know what is the code below doing? /******************************************************************************/ /* Timer 0 interrupt service function */ /* executes each 1ms @ 20 MHz Crystal Clock */ /******************************************************************************/ #define INT_CLOCK 0.001 // timer interval 0.001Sec #define XTAL 20000000 #define X2 0 // set to 1 if in X2 Mode #define _CLOCKVAL ((unsigned int) ((XTAL/(12/(X2+1))) * INT_CLOCK)) #define T0_CLOCK ((-_CLOCKVAL)+13)
Well, I'd guess it's calculating the reload value for timer 0 required to generate an interrupt approximately every millisecond with a 20MHz clock. I think you need to have a look at a good book on 'C'. I'd recommend: "C: A Reference Manual" by Harbison and Steele ISBN 0-13-326224-3 I think you should also read the datasheet for the device in conjunction with the "Intel MCS 51 Microcontroller Family User's Manual" which you can find on the Intel website. Stefan
