Timer
Hi
I just got this program from keil and i am tryin to understand and i hope somebody out there can help me.
First:I dont understand how this simple line
define Port_D XBYTE [0xFFA0]defines port 1(bit 0,1,4,5).What is FFA0 doin there?
Second:What is the line below doing? #define _CLOCKVAL ((unsigned int) ((XTAL/(12/(X2+1))) * INT_CLOCK))
Thanx in advance
Martin
#define Port_D XBYTE [0xFFA0]
// bit 0: switch S1
// bit 1: switch S2
// bit 4: LED D1
// bit 5: LED D2
#define DipSwitch XBYTE [0xFF80]
static unsigned char IOinfo = 0xFF;
static bit SendInfo;
/* Timer 0 interrupt service function */
/* executes each 1ms @ 20 MHz Crystal Clock */
#define INT_CLOCK 0.001 // timer interval 0.001Sec
#define XTAL 20000000
#define X2 0 // set to 1 if in X2 Mode
#define T0_CLOCK ((-_CLOCKVAL)+13)
