Advice on button pressing!
I am using the the philips LPC764, you can set up all the pins on port 0 as keyboard interrupts - which i have done ok. I have one button on each pin.
I have tested it ok with one button but when using 2 buttons how do i tell in the keyboard interrupt routine which button/pin was activated?? Trying to catch the port status does not work as I assume the port has gone back to high by the time the interrupt is fired and released....
I have the use of KBF = which is the keyboard flag (bit) and i have set the interrupts using EKB=on, EA=on and KBI bits =on.
Barry
