Dear Expert, I use EEPROM 24LC512 and I try to write data with Page Write Method, but it is only first byte can be write in EEPROM but other 127 bytes cannot write. Do you have any suggestion or any example to solve this problem? Thank you for all reply. :) Nat.
Describe how you implemented the page write algorithm in more detail. If you send a STOP bit anywhere in the sequence, it will start writing from that point. If you send a repeated START bit, it could also cause problems.
Thank you. This problem was solved. :) Nat.
HI Would it be possible for you to let me know what was the problem and how did you solved that? Thanks
Can u plz share wat was ur problem and how u have solved
"Can u plz share wat was ur problem and how u have solved" Could you repeat that in English please? Stefan
I'm sorry that I did not visit this forum for long time. So if anybody has a same problem please send email to me. I will send you for some C code. OK? my email : natahn@hotmail.com
