T3 interrupt problem
Hi all,
I am using T2 and T3 timer with T3INT interrupt as below:
void init_T2(void)
 T2 = 195; // for 10ms with 51,2 resolution
 T2CON = 0x0027;   // reload, timer mode
void init_T3(void)
T3 = 195;    // for 10ms with 51,2 resolution
T3CON = 0x00C7;
T3IC = 0x0030;  // level 12, group 0
interrupt (T3INT) void T3_ISR(void)
 counter++;
 sec = counter/100;
 min = sec/60;
 tenth = sec/10;
 hundreth = sec/100;
void main(void)
   init_T2();
  init_T3();
  IEN = 1;
 while(1)
My problem is that I never get into interrupt routine.
I have checked my code a number of times but I don't find anything missing. It should work.
Can somebody point out if I am missing something?
thanks for help
regards
/M
  • Hi all again,
    I found the reason why interrupt was not active:
    void init_T3(void)
    T3CON = 0x00C7;
    T3IC = 0x0030 disable interrupt
    now I changed to
    T3IC = 0x0070
    and it works
    regards
    /M
