Hi, I plan to develop a testing tool, which get usecases from a database and drive the testing object automatically, the results need to be save back to database. uVision run the debug functions, but it output to the output window. How can I send the data to uVision, and get output from it? I am using VC++. Thanks. Huang
You may use the DDE interface documented under: http://www.keil.com/appnotes/docs/apnt_143.asp
