How to re-allocate the code variables to bank X
code int iMatrix[9]={..........}
I apply this source file to bank 3,however,
the linker allocates iMatrix to common area.
May I change the area to any bank to save comon area space,and How??
Please do me a favor,and thanks ....!!
  • Have you tried the BANKx directive to place that segment in a particular bank?
    If you want to seperate out just one particular declaration from other code/constants, you'll need to put it into its own file so that it will get its own segment name.
  • Mr.Davis,
    Thanks for your advice,
    I've ever tried to put the function among different bank,It work well,however the code data,for example the integer matrix I declare and set this whole file apply to Bank X,The linker allocate whole file function to Bank X ,except the code data matrix.(code data in common area).
    Anyway,if you have further advice,just tell me.I appreciate your kindly help.
