Putting main() into a library
i'm trying to solve the following situation: building a library which contains some functions and also main().
The goal is, to use this as a framework and link it with a user supplied module which only contains some callback functions.
Building up the library is not the problem. Listing it with LIB51 shows:
DOS LIBRARY MANAGER LIB51 V4.01
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 1997
LIBRARY: MYLIB.LIB
>LIB_FUNC
>>F_MY_LIB_FUNCTION
>LIB_MAIN
>>MAIN
(>'s added because the forum doesn't support blanks at beginning of line :-)
So main() seems to be put in the library as i want it.
The problem is linking it with the user supplied module. The linker does not find a root segment. So i tried to add main() as a root segment by specifying
overlay(* ! MAIN)
as a linker option. But the linker never finds main() at all.
Here's my complete linker call:
L51 user.obj, mylib.lib to mytest.abs ramsize(256) XD(0000h) overlay(* ! MAIN)
It results in:
*** WARNING 11: CANNOT FIND SEGMENT OR FUNCTION NAME
*** WARNING 16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS
SEGMENT: ?PR?F_THE_CALLBACK?USER
*** WARNING 10: CANNOT DETERMINE ROOT SEGMENT
(where F_THE_CALLBACK is a user supplied function called from within main() )
So, even the overlay manager seems not to "see" main.
Where's my mistake? Is main() processed different from other functions? Is it impossible to put main() into a library?
Thanks in advance for your help.
FRANK
