Beginners question; RD/WR doesn´t work
I have quite recently started working with uVision and an Atmel MCU, and I think that I may have done something wrong in my settings... Here goes:
The problem is that both RD and WR goes low when I try to read or write.
My hardware is an Atmel T89C51RD2 MCU, and it doesn't matter that I set the AUXR register EXTRAM bit to one - the RD/WR toggles and both are low at the same time.
My code looks good enough; the write cycle assembler code looks as follows:
C:0x0015    9098FC   MOV      DPTR,#addressbyte(0x98FC)
C:0x0018    7401     MOV      A,#0x01
C:0x001A    F0       MOVX     @DPTR,A
So both the address and the data are correct.
My target options has been a lot of different. I really do not know what to do with them - aren't a lot of them set in the STARTUP.A51 file? do I need to set them at more places?
Anybody that has experienced the same or similar problem?
Most grateful for help.
  • Have you checked with a Ohm-meter to make sure the lines aren't shorted together? No 8051 that I'm aware of will drive both RD and RW low at the same time, so it sounds like a hardware problem.
  • Thanks for the help, Robert!
    After having consulted with my oscilloscope I found that the problem was the output low voltage of the mcu, which is as high as 1V. All circuits connected so far work under that circumstance, but the hardware I try to connect does not.
    Anybody out there that knows if it is normal that an mcu has 1V output low voltage? I have never checked on the few projects I have worked with, but it seems rather high, doesn't it? Specially since the data sheet says max 0.45V.
    I have now ordered a new mcu - hopefully that's where the problem is.
    To be continued...
  • Anybody out there that knows if it is normal that an mcu has 1V output low voltage? I have never checked on the few projects I have worked with, but it seems rather high, doesn't it? Specially since the data sheet says max 0.45V.
    if you see anything that differs fron the datasheet, you can be sure that eithet your circuit or the chip is bad.
    Is the 1V measured relative to the ground pin rather than some arbitrary ground point?
    What is the low output voltage (measured as above) if the pin is not connected to anything.
    Do these two simple tests they may be educational.
