Redirecting Interrupt
I'm redirecting my interrupts using the code
CSEG AT 0000BH
LJMP myisr
I've a number of files. Where should I put this code (which file... does it matter)? Should I create a segment called 'myisrtable' and place all ISR address in it?
Regards,
KC
  • I do not think it matters - as far as the linker - where you put the vectors; however, having the vectors in one module (I do, together with the ISRs) gives the advantage of an immediate view of completeness (you do put reti in unused interrupts, I hope).
    Also I have always had ALL ORG statements in one module (that keeps me from making overlap or gap mistakes as opposed to having ORGs all over the place)
  • Hello,
    Thanks Erik!
    ** there's no need to post 6 times **
    Regards,
    KC
