I'm having some problems testing bit 0 of a variable to see if it's a 1. Here's the snippet of the code:
if ((bWork && 0x01)==1) bTemp = bTemp|0x01; else bTemp = bTemp & 0xFE;
You are using a logical AND instead of a bitwise AND. The following code does what you want:
if ((bWork & 0x01)==1) bTemp = bTemp|0x01; else bTemp = bTemp & 0xFE;
bTemp ^= (bWork & 0x01);
&& is logical and. & is bitwise and. The given snippet will take the if path whenever bWork is "true" (non-zero). (The other operand, "0x01", is always true, so it only depends on bWork.) You probably want:
if ((bWork & 0x01) == 1)
Thanks. And thanks for the tip on the if .. then statement Jon. You learn something new everyday.
"You learn something new everyday." Looking at your original post, you probably also want to check out the |= and &= operators in your 'C' text book (and += etc).
